Having a lot of issues, need to get to the bottom of this - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 06-19-2014, 05:44 AM Thread Starter
Cummins_Killer's Avatar
Okay so im gonna list all my problems in a chronological order,
First, in the winter, a loud buzzing noise started when turning the key to the wts position, this noise still occurs, just not when the truck is still warm.
Next, lights are dimming when going down to an idle, then brighten when rpms get above 1k
Then, o/d light started flashing, had a slip only when i powerbraked the rpms up to around 1200, then let it back to an idle and then drove.
Transmission was rebuilt, same problem, but diffrent code being shown.
The same thing above happend about 3 times, same problem, diffrent code.
The slip only occurs when the trans is in drive, not when in 1 or 2.
Also occurs very frequently in 4x4, much more then 2x4.
My trans is under warranty, but the guy really isint sure whats wrong so he just keeps replacing the sensors. He said his next try is to look in the drum.
Also, now when the o/d light flashes and i shift into neutral or park, it goes into high idle for 2-3 seconds.
So my question is, does anyone have any idea what may be wrong? Im tired of going back and forth to the tranny shop.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-Diamond Eye 4" Turbo Back Straight Pipe
-33" Nitto Trail Grapplers on 18" XD Diesel
-2.8" Leveling Kit
Cummins_Killer is offline
post #2 of 12 Old 06-19-2014, 09:06 AM
Quoted: 12 Post(s)
I am not sure about the other issues you are having but the lights dimming seems to be your alternator is on its way out. I would have it tested or monitor your voltage while your driving.
Now I may be way off but if you are having electrical power issues this could be causing the other problems that you are seeing. If the PCM and and other sensors are not getting the proper power then the signals could be getting corrupted and causing issues.
Heavy_GD likes this.
Will335i is offline
post #3 of 12 Old 06-19-2014, 10:08 AM Thread Starter
Thats kind of what im thinking.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #4 of 12 Old 06-19-2014, 10:09 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
i agree with will.
start with the charging system and make sure everything is working.
all the electronic crap doesnt work coreectly when not getting enough power.
heck my dang quad wont even run if the batteries low
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 12 Old 06-19-2014, 03:24 PM Thread Starter
Should i just start voltage testing things?
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #6 of 12 Old 06-19-2014, 04:48 PM
Quoted: 258 Post(s)
check the grounds/ positive cables.
how old are the batteries? possible bad cell?
check alternator output.
post #7 of 12 Old 06-19-2014, 04:52 PM
aussie=effie
bob harris's Avatar
ALTERNATOR LIKE THEY SAID
bob harris is offline
The Following User Says Thank You to bob harris For This Useful Post:
Heavy_GD (06-19-2014)
post #8 of 12 Old 06-19-2014, 06:18 PM Thread Starter
How do i check alternator output?
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-2.8" Leveling Kit
post #9 of 12 Old 06-19-2014, 06:38 PM
Joel's Avatar
Quoted: 10 Post(s)
It should be putting out around 14V while running.
If it's not than its time for a new one
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #10 of 12 Old 06-19-2014, 08:39 PM
Quoted: 780 Post(s)
Yup, should be 13.5-14.5
Corey@CNCFAB is offline
