2 stroke oil additive
I was thinking of trying to add 2-stroke oil to a tank of fuel. I know people have done it and it helps lube the injectors. Did i need to buy ashless or smokeless 2 stroke oil? Or are they the same thing? Everyone i found said ashless, so i just wanted to make sure i got the right thing so i don't do any injector damage.
ashless........never heard of smokeless
Just curious, would 2 stroke for a weed wacker work?
You need ashless Dan. The cheapest way to do it is get the Supertech brand from wal mart
thats exactly what i picked up. Someone had said smokeless at one point and i know my strikemaster oil for my ice auger says smokeless on it.
1 oz. per gallon should be just fine
Yep thats the ratio i was going to go by.
as long as it ashless, I assume it will work fine, IIRC most people use the marine oil
you dont want to use a 2 stroke oil for chainsaws or weed eaters, they run a lot hotter than there marine or water cooled brothers. at the engine temps we run, you would never burn all the oil, and start gumming up things.
make sure its a TC-W3 rated marine oil. |
