battery light - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-19-2014, 05:26 AM Thread Starter
battery light
my battery light flickers on and off. Then it won't come on for a couple of days. I took readings on the batteries.
Truck off - 11 volts
Truck running- 12 volts
Truck running with a/c & radio on -14 volts
I believe the batteries are good with these readings, but not sure. What else can I look for?
bertieb is offline
post #2 of 3 Old 06-19-2014, 05:50 AM
BrodieBiking's Avatar
Your alternator is probably starting to go.
Sent from AutoGuide.com App
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #3 of 3 Old 06-19-2014, 06:12 AM
Just had the same problem. when the battery light was on one of the wires coming off the top of the alternator was only putting out 1.7V. New alternator fixed the problem.
jontashley is offline
