Looking at a 2002 with 340,000km/212,000miles - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-18-2014, 12:26 PM Thread Starter
I'm looking at a 2002 7.3 with 212,000miles. Original auto trans, hpop has just been done. The truck will be used to tow just under 7000lbs 24/7, city and highway. Would this be a good buy? Looking for low maint and reliable work truck.
01Bora is offline
post #2 of 12 Old 06-18-2014, 12:41 PM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
What are they asking would determine if it may be a good deal or not.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #3 of 12 Old 06-18-2014, 12:45 PM Thread Starter
$6900 Cdn. Should I expect to be putting some money into it? Like the trans.
Edit: I'm more concerned with reliability and maintenance than a good deal
01Bora is offline
post #4 of 12 Old 06-18-2014, 07:45 PM Thread Starter
Bump......
01Bora is offline
post #5 of 12 Old 06-18-2014, 09:01 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
At that mileage the trans and injectors are on their last leg. Trans $3k, injectors $2k. Depending on cab configuration and trim package it could be around an ok price. Around here a ccsb xlt goes for around $10-13k depending on condition. I'm thinking you will have $6k total into maintenance and injectors and trans. So figure that into the price before buying. I would check blow by first by flipping the oil fill cap and setting it back on the spout. If it blows off it's bad if it rattles of your ok. Check for rust. I know I'm missing some things but I'm tired. The price is ok if it's in good condition. You should post a little more about it. Like cab configuration, bed size, trim level, rust.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
01Bora (06-18-2014)
post #6 of 12 Old 06-19-2014, 05:29 AM
hansel's Avatar
Quoted: 94 Post(s)
I just picked up a 2001 with 224K, and it will need some TLC for sure, I've already flushed the coolant, changed the oil with new filter, flushed the transmission (that was fun) I'm use too a 2wd truck this one is 4wd and I was short on fluid so I had too make a trip back too the parts store for more fluid. I will change the fuel filter as soon as a new lid show's up because the previous owner used that fuel filter/lid combo
With that mileage I will see what or how long the injectors will go I have run some Diesel Kleen which is helping with the start up's and running better, so give it some time and I should be okay. He said the transmission had been rebuilt 2 years ago, but I will keep my finger's crossed after seeing how the fluid change went.
Good luck
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 12 Old 06-19-2014, 06:17 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
I reread my last message and I'm not trying to discourage you I'm just trying to let you know what is coming. Your tranny or injectors could go out tomorrow or 30k from now. Just keep it in mind that it will happen sooner or later. I would buy one with those miles if it was in good shape. Good luck.
01 f-250, Standard
sbluke55 is offline
post #8 of 12 Old 06-19-2014, 07:02 AM
Montstroke's Avatar
With maintenance comes reliability. Now that I recently bought mine (with 217k), I have learned these trucks are not for those who dislike regular maintenance. But if you can dedicate your self to staying on top of it, the truck will last another 100,000 easy.
I would think you might plan on a preemptive tranny rebuild/upgrade with your stated amount and type (city) of towing you will be doing. Maybe factor a chip/programmer to help the shifting of the tranny also.
Injectors are a roll of the dice. If the previous owner was up on maintenance and changing fuel filters regularly I would not stress them too much, but start putting some money back for them and changing o-rings on them may not be a bad idea. Look it over carefully and ask if there is any records.
2001 F250 CCSB
Less than cold air intake
RR Billet Wheel
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
6 PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #9 of 12 Old 06-19-2014, 03:19 PM Thread Starter
Thanks for the input guys!
01Bora is offline
post #10 of 12 Old 06-19-2014, 03:28 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Thats way too much money unless its a lariat.
I paid 6000cdn for my 99 with 200 000kms.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
