What brand of batteries - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 19 Old 06-17-2014, 06:11 PM Thread Starter
Quoted: 95 Post(s)
Is time for new batteries I sometimes have some hard starting issues and voltage will drop to 9 volts when cranking. Got them tested one failed and one barley passed, the date on them is 12/08. What brands do y'all recommend and what kind of warranty do they have.
00 f250 ext. cab, lb, 4x4, 146,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Duck Commander Mts, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dorman up pipes,IAH delete, ccv mod, 6637 filter, auto meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #2 of 19 Old 06-17-2014, 06:19 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 109 Post(s)
I don't remember the amps/volts of mine, (Google it). But I have two duralast batteries I bought at Walmart that have a pretty good warranty where if anything happens no questions asked I get a replacement. The truck starts right up, I don't even have to wait for the WTS light to go out in case I needed to.
kinnisoj likes this.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #3 of 19 Old 06-17-2014, 06:27 PM
BryceB's Avatar
I thought Duralast was an autozne and Everstart was Walmart.
I got a good deal from the local,Ford Dealer on Motorcraft Batteries. look on Owner.ford.com (register if you haven't already) and look for coupons and specials at local dealers. They were cheaper than anyone but Walmart.
I had Duralast prior to these and they crapped out around 4 years. The originals lasted better and 7 years.
Make sure your cables and connectors are in good shape and not corroded up inside the insulation on the cables.
john galt likes this.
2001 Ford F-250 SD CCSB 7.3 PSD - AIS Intake, Zoodad,
MBRP 4" XP Series Exhaust w/ Muffler, HD4R100, 26 row Trans Cooler, Fumoto Valve,
285/75R16E BFG AT KO, Pioneer AVIC-Z130BT Nav, BOYO VLT-422C Back Up Camera,
Scangauge II, Glowshift 3 Gauge Pod (EGT,TFT,Boost), PHP FU Chip, Huskyliners, Huskyliner Mud Flaps, Warn Premium Hubs, Riffraff Boots/Clamps/inserts
Dyno'd at Mo's Speed Shop 11/3/12 - 307rwhp / 651rw ft-lbs <<<--- On PHP 120Race tune
BryceB is offline
post #4 of 19 Old 06-17-2014, 06:31 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I'm running o Reilly brand in my obs, the SD has Wally World brand, both have zero issues starting
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 19 Old 06-17-2014, 06:33 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ill second the wal mart cheap'os. Mine are going strong. And a good thing about them is just about every town in the USA has got a store now so if one fails while Im on the road...no problem!
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 19 Old 06-17-2014, 06:34 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
I have Deka brand. Made in USA (Pennsylvania) i got 2 1040 CA 900 CCA no complaints yet. have them for a few years price was competitive but supporting a USA company. plus the batteries are overkill.
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
post #7 of 19 Old 06-17-2014, 07:29 PM Thread Starter
Quoted: 95 Post(s)
Everstart max from wall mart looks like a good deal 850 cca, 3yr warranty, and only $110 a piece.
00t444e is offline
post #8 of 19 Old 06-17-2014, 08:23 PM
Horizon122's Avatar
Quoted: 109 Post(s)
Maybe it depends on your region as to what they stock. But here in Jersey (NY still has no Wal-Mart) it was mostly all duralasts they had on the shelf. I don't remember the price but it was about $100 give or take. I can't exactly say how long they last as I just put fresh ones in this year and the pair I had before were still good and only died because I had a power drain issue but I had them for a few years without an issue.
post #9 of 19 Old 06-18-2014, 10:45 AM
jeep1980's Avatar
Quoted: 2 Post(s)
Garage
I picked up a pair of interstate batteries back in February from a local truck shop. I think I paid about $125 plus tax for each of them.
jeep1980 is offline
post #10 of 19 Old 06-18-2014, 10:49 AM
early99psd's Avatar
Quoted: 12 Post(s)
I only got 3 years out of my duralast 8 year batteries. Now on my second set. Isn't there only 3 or 4 manufactures of batteries?
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
