air conditioner not working all the time - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-17-2014, 03:58 PM Thread Starter
markfull's Avatar
99 f350 7.3/ my air will blow cold at first but when cruising down road it will stop blowing cold air. if i slow down and then speed up like at a intersection it will blow cold air for a few minutes then quit again.
markfull is offline
post #2 of 6 Old 06-17-2014, 04:42 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
Low on freon
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 6 Old 06-17-2014, 05:34 PM
Quoted: 3 Post(s)
Could be low on Freon or maybe the pulley shims?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #4 of 6 Old 06-17-2014, 07:18 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I would start by first taking a garden hose to your condenser and cleaning out the gab between it and the radiator/intercooler.
Then I would check your AC pressures. You're looking for something in the 35-40 PSI on the low side.
Doubt its the clutch, if it was shimmed out too far it would be grinding when it tries to engage.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #5 of 6 Old 06-18-2014, 07:43 AM
Mine was doing the same thing when I bought it. Checked the refrigerant and it was good. Mine ended up being the air gap for the compressor clutch plate was too large. Next time it does it if you can stop get out and see if the plate on the front of the compressor is turning or not. Removed a shim, corrected gap, Worked Great ever since. You can Google it and find how to check it and set it.
2000 F250 CCSB Auto
DIY Intake with Amsoil Filter
Hutch and Harpoon Mods
Hydra
Riff Raff Billet Wheel
Riff Raff Boots
FRX
ISSPRO EV2 Boost, Pyro, and Trans Temp
EBPV Deleted Pedestal and Outlet
Bellowed Up Pipes
4" MBRP
315/75/16s with Add A Leaf
RebelRiderNC is offline
post #6 of 6 Old 06-18-2014, 09:17 AM
Bill Kay's Avatar
Quoted: 2 Post(s)
The problem is when the electrical coil is cool it has more magnetic pull (this is why it starts out cooling). Then when the compressor heats up, and the cabin temp reaches set point and the compressor drops out. When it calls for the compressor to engage again the magnetic coil is energized but the air gap is too great for the heated/weakened coil to pull it in. A good test is to have your truck at operating temp and with the key on and the engine off turn the AC control to max and see if it closes the air gap on the compressor. If it does not, push on the clutch face or tap it with a whench or screwdriver and if it closes then the shim needs removing. FWIW my truck had the exact same symptoms and the air gap was the problem. It's an easy test/fix and best of all its FREE!
Bill Kay is offline
