How to Tell if your Truck is Federal or Cali Truck - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-17-2014, 11:01 AM Thread Starter
Quoted: 2 Post(s)
I'm getting ready to order my DP tuner and need to find out if the truck is a 49 state truck or a Hippie Loving California Truck. What I do know is the truck was bought new In Dallas TX in 2000. Stayed in Texas its whole life till i Bought it in April. I'm 99% sure its a 49 state truck but want to be damn sure before I order my DP and Tunes. What do I need to look for?
2006 F-350 FX4 6.0 Lariat Dually Loaded White/Gold
-ARP studded
-Heads flanged and ringed
-Deleted
-Sinaster Coolant Filtration
-Coolant Bypass
-4 inch straight pipe
-SCTx4
-Tuned by Insane Irish Diesel
SOLD-2001 F-350 7.3
- Built E4OD
- ATS Ported Housing
- Wicked Wheel 2
- MBRP 4inch Turbo Back
- Grand Rock Dual 5 Inch Aussie Stacks
- SCT X3
Blckchry is offline
post #2 of 4 Old 06-17-2014, 12:05 PM
lightning95's Avatar
It should say California emissions on the under hood sticker. Mine is a Cali truck. The canned tunes from php are few with 100hp max.
I need a different ECM.
02 F-250 ccsb 7.3 auto, 8" fabtech, 37" toyo, 4.30, 4" straight pipe, AFE intake, hydra chip, riff raff wheel, tugger kit and powerstruck tunes.
95 Lightning fast by NX nitrous
07 Yamaha R1
lightning95 is offline
post #3 of 4 Old 06-17-2014, 12:57 PM
Montstroke's Avatar
Call a dealer and see if they can run the vin and tell you. Also, as mine is a hippie lover, there will not be a glow plug relay, instead there is a control mod that is about 3x5x2 inches and silver in its place.
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips
Of course its the 200 dollar one.
2001 F250 CCSB
Less than cold air intake
RR Billet Wheel
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
6 PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
post #4 of 4 Old 06-19-2014, 01:25 PM
early99psd's Avatar
Quoted: 14 Post(s)
When I had DP all they needed was the ECU code
Sent from AutoGuide.com App
MB HPOP, PHP Hydra, AFE stage 2, 4" turbo back exhaust, gutted cat, ford reman trans, JW valve body, 6.0 trans cooler, EGT trans temp boost gauges, Hutch and Harpoon mod, riffraf FRx, Pro Comp leveling kit, 1" zone shackels, 08 rear diff cover, 315 Toyo AT2,
early99psd is offline
