Downpipe in the way of shackle bolt - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-16-2014, 06:27 PM Thread Starter
Cummins_Killer's Avatar
Title pretty much says it, the down pipe is in the way of the upper shackle bolt, is their anyway to remove it without taking off the down pipe? Also my exhaust is wedged in between my shock and spare tire, do i need to remove the spare tire in order to get it off the shock or does anyone have any other suggestions? Thanks.
Early 99 F-350 4x4
-TS 6 Position Chip
-6637 Intake
-Diamond Eye 4" Turbo Back Straight Pipe
-33" Nitto Trail Grapplers on 18" XD Diesel
-2.8" Leveling Kit
Cummins_Killer is offline
post #2 of 4 Old 06-16-2014, 06:48 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Well if its in the way and you need to take out there bolt you only have one option.
Then put the bolt in the other way when you reassemble for next time.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 4 Old 06-16-2014, 06:51 PM
heykw's Avatar
Post some pics
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #4 of 4 Old 06-16-2014, 10:49 PM
Joel's Avatar
Quoted: 10 Post(s)
Cut the bolt and push it out the side you have access too.
Then reassemble from the other side like Shultzer says.
Probably way more work than just loosening the exhaust at the turbo and pushing the down pipe off to the side, but at least you have options.
on the rear can you just lower the spare tire to gain whatever access you need?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
