Dual Alternator question - Ford Powerstroke Diesel Forum
post #1 of 28 Old 01-11-2009, 06:42 PM Thread Starter
I have a 2000 CC LB 7.3 and am looking to add a second alternator. I believe the trucks that came with the tow package had this. I was hoping Guzzle would have a write up on this but I didn't see it.
Is there a special bracket that I have to get for the lower alt? or is it just a matter of a new vbelt and alternator?
____________
Ed
2000 F250 CC,LB, white whale addition
6in lift, 35" Nitto Terra Grapplers,SuperChips Cortex,Limo Tint,optima red tops
CaptAhab is offline
post #2 of 28 Old 01-12-2009, 05:50 AM
dubl_t's Avatar
I don't know about "tow Package" dual alts, but I'm pretty sure ambulance packages had duals. you might cruise the wrecking yards to find the bracket, and do a little research for the wiring.
Why do you want duals anyway? a welder maybe?
mods thus far:
1704 tuner gizmo, BHAF, 4" DP to 5" stack, FPR w.109 shim, disconnected wastegate, plethora of gauges, 10k mod w/ 20k resistor (removed after it jacked up my connector), 17*HPOP (not really), hybrid sticks (I wish), some kinda badass turbo (another lie), mega body damage (that's gospel).
dubl_t is offline
post #3 of 28 Old 01-12-2009, 06:03 AM
2000 7.3 6speed's Avatar
I thought it was the snow plow package came with duals.
but i think the top radiator hose is different.
i remember reading some where you have to pull the hose off to get the belt off
2000 7.3 6speed is offline
post #4 of 28 Old 01-12-2009, 06:13 AM
pwrstroke6john's Avatar
The plow prep came standard with a bigger alternator, and it was a option on about any package to go to the dual setup
2005 F350 crew cab short box
6 inch pro comp lift
35x12.50-20 Nitto Trail Grapplers
Moto Metal Rims
5 IN MBRP Turbo Back Straight Pipe - 6 IN Tip
AFE Cold Air Intake
SCT Tuner
Coolant Filter
EGR Delete
15% Window Tint
6000k HIDS
Bushwacker Flares
Buckstop Front Bumper
Custom Rear Bumper
Weatherguard Box
pwrstroke6john is offline
post #5 of 28 Old 01-12-2009, 07:25 AM
tubular031's Avatar
I wonder the same thing. It would be nice for charging batteries. I am going to put a few more in my 5th. wonder how mad the single alt in my truck gets when you stack 5 or 6 batteries on it
From what I understand, the ambulance packages had duals and you could add duals as a factory option.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #6 of 28 Old 01-12-2009, 07:44 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
FYI: My truck has the amb package, has duals... don't know about the others with or with out... this prob doesn't help you much, as you already know this...
As the others said, check junk yards for a amb with dual alts, bracket should be bolt on, not sure how the wiring would tie in tho...
Good luck!
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #7 of 28 Old 01-12-2009, 07:53 AM
ABoyAndHisToys's Avatar
Send a message via AIM to ABoyAndHisToys
I swapped my motor a year ago with one that had single alt. setup. The battery harness is different and there is a bracket that needs to be added. I'll look around for the pics.
2001 CC Long Bed Fat A$$
New Heart w/Forged Rods @ 108,000miles (Damn PMR's).... with some goodies on it
Brandon
ABoyAndHisToys is offline
post #8 of 28 Old 01-13-2009, 04:21 PM Thread Starter
interesting
Yea when my alternator blew up a little while ago I went to Ford and got a new one, they were askin me about whether my truck was single or dual....I said single but checked around and found that some of the trucks came with them.
As far as taking the radiator hose off, I have to do that just to mess with the belt anyway, and my truck is a single alt. But I didn't know you needed a different bracket.
Yea I wanna run some lightforce 170s, around 3-4 across the front and I am putting in my audio system, in the past when I put my audio system into vehicles, (most car POSs) it would dim the lights which usually means you are not running enough amperage to run everything. I have a 110amp alternator but thought if I could find a to run one for the actual starting system and regular truck functions and run the other for my aux lights and sound system that that would be a better option.
ABoY-if you can find those pics I would appreicate it.
Thanks for the replies!
____________
Ed
CaptAhab is offline
post #9 of 28 Old 01-14-2009, 05:36 AM
tubular031's Avatar
when I had my last "big" system in my other truck I use to get the dimming lights too when the bass would hit. I added a 2 or 3 farid (whatever they call it) cap right next to the amp and that helped a bunch! I was only pulling about 50 amps on the booms (measured with my clamp meter) and my alt was a 110 on that truck. added a cap, and the dimming lights just about went away
post #10 of 28 Old 01-14-2009, 09:29 PM
Dual alternators is standard of ambulance packages. It was probably an option on other trucks and vans too.
The obvious thing that will be needed is the lower bracket. No-brainer there. Wiring the main alternator output is not a problem either. The problem I see is that the alternator is controlled by the PCM. The PCM tells the alternator when to charge and when not to. If you installed a Ford lower alternator (BTW the upper and lower are different), you may have no way to actually activate it. I don't know if the PCM is already set up to accept it, provided you knew what pin to attach it to. I'll try to remember to check my PCED and wiring diagram books tomorrow to see if it is possible.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
