how hot is too hot "egt"
i have 5" mbrp stacks dp tuner,140 extreme it was straigt stacks ran about 1200" really beatn on it/ through a mbrp muffler on their quiet it down a littel bit now she gets around 1400" scosh more
Was it like up a mountain in 100* weather?! Mine don't get over 600 without towing something ever, mods in sig.
na its like 3o" outside just put the muffler on ther went for test ride down the road not even on the highway just holden her to the floor for about 15 sec
Is that before or after the turbo temps?where is your pyro located?
pyros in the left exhuast manifold
If yours does not get over 600 in normal driving then your pyro probe is post turbo... |
Yes. It is. I forgot that detail. But there isn't a 600* loss is there?
Pre and post turbo temps can vary as much as 4-500 degrees. At 600 post turbo you are roughly running about 1000 degrees.
I had a post turbo pyro on my old truck for a while. Cruising at 70 it ran about 500 empty loaded I saw 600. Same truck, tunes and loads post turbo pushed 650 or so empty 1100 loaded |
