Too run used tranny fluid or not - Ford Powerstroke Diesel Forum
post #1 of 17 Old 12-17-2006, 06:44 PM Thread Starter
dukey_78's Avatar
My Cousin is a tech and was telling me that i could run used tranny fluid as fuel. the reason is that it burns cleaner, cleans injectors, and is cheaper that diesel. i was just wondering wat everyone else thought about it?
dukey_78 is offline
post #2 of 17 Old 12-17-2006, 06:47 PM
im fat and ugly
stump0331's Avatar
maybe someone with more knowledge can give ya a better answer but i dont believe id put that through mine
2004 Excursion
stump0331 is offline
post #3 of 17 Old 12-17-2006, 06:49 PM Thread Starter
dukey_78's Avatar
well he has got 100 gallons saved up for when he gets his so he is a pretty strong beleiver
dukey_78 is offline
post #4 of 17 Old 12-17-2006, 07:12 PM
Power Strokeaholic
super_stroke's Avatar
that's a big NOT. the rubber in the fuel system isnt designed for tranny fluid. it will eat the rubber seals. i was going to mix tranny fluid with diesel and got shot down. then marc explained it to me about the diffrent types of rubber used between the two. wont work.
Bill
2000 f-250 4x4 ex cab 7.3 psd. diablo programmer, TS 6 pos.
, 4" exhaust turbo back w/ 5" stacks, wicked wheel, HX cross over, zoodad mod, 6637 mod, boost pyro & trany on the a pilliar. 315/75/16 bfg mt's,.superwinch hub's, 6.0 trans cooler, banks trans command. sky jacker leveling kit
super_stroke is offline
post #5 of 17 Old 12-17-2006, 07:30 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Noooooooooooooooooooooooooooooo!
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOO
OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
post #6 of 17 Old 12-17-2006, 07:38 PM
International Threat
Marty's Avatar
If you can't tell from the above posts the answer is NO, don't do it.
It would be one thing to use NEW tranny fluid (it would eat the rubber etc.. like bill said) but USED tranny fluid will have small metal particles from wear on the internals that you DON'T want scraping the cylinder walls of your engine.
Also I think the lubricity content is down (which is bad for injectors), but don't quote me on that.
Either way, the answer is stick to diesel.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #7 of 17 Old 12-17-2006, 07:51 PM
WD40's Avatar
Quoted: 31 Post(s)
(You DON'T want scraping the cylinder walls of your engine.)
Cylinder walls would take the Scraping for a little while but I don't think the injectors would take a tank full of it at 75 diesel/25 UATF.
Like everyone has all ready said. NO!NO!
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #8 of 17 Old 12-17-2006, 08:45 PM Thread Starter
dukey_78's Avatar
the fluid is filtered thru the tranny filter when flushed then again before using there cant b ne metal shaving in it or the valve body would plug up. There is a diesel tech that runs strait tranny fluid in his 03 7.3 not had a problem yet. i understand wat your saying. so then why can you burn veggie oil?
dukey_78 is offline
post #9 of 17 Old 12-17-2006, 08:55 PM
Marty's Avatar
Veggie oil actually has better lubricity then diesel! The biggest thing is it's gotta be WARM to use it. You gotta start out on diesel and then switch to veggie.
As for the filter getting the particles out, have you ever dropped the pan on your 4R100? I'm sure you'll be surprised when you see what's collected on the magnetic drain plug!
I for one would not like to risk a 10,000 dollar motor on comprimised fuel just to save a few bucks because honestly, how long is 100 gallons gonna last you? Me, about 1 month. My truck is currently at 126k... it should be around another 150 or so.... that's alotta gallons! After contemplating that scenario, is it worth the small savings?
2001 F250
11.62 @ 115.79
Elkton, Maryland
Marty is offline
post #10 of 17 Old 12-17-2006, 08:56 PM
im fat and ugly
stump0331's Avatar
WEVE GOT THE PERFECT MEMBER TO HELP YA THERE (chenry) clay runs a vegistroker system
2004 Excursion
