"hpop".... what is it and what does it do???? - Ford Powerstroke Diesel Forum
Old 01-08-2009, 08:32 AM
Guys, I'm new to diesels and I am seeing posts that make reference to the "hpop" and it's oil level. Would someone please elinghten me as to what this is, where it is and what it does.
Thanks, George
Old 01-08-2009, 08:36 AM
International Threat
High pressure oil pump, and the oil level you check is in the resevoir. If it's not filled as it's supposed to, it will make the truck hard to start. It can be bled off by the IPR if it's malfunctioning.
Old 01-08-2009, 08:41 AM
ADMIN AND TECH
the high pressure oil pump is fed by the low pressure oil pump to increase oil pressure inside the injector rails , the icp sensor monitors this pressure and sends that back to the pcm as an input , the pcm then adjusts the duty cycle of the ipr to control how high the pressure is produced by the hpop , without high pressure oil or the correct pressure , engine will not run or not run correctly
Old 01-08-2009, 08:51 AM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
dont forget to change the hpop oil
Old 01-08-2009, 08:54 AM
ADMIN AND TECH
oh lord here we go
Old 01-08-2009, 08:59 AM
Originally Posted by SCUFFY828 View Post
oh lord here we go
im just kiddin man
Old 01-08-2009, 09:02 AM
Old 01-08-2009, 09:04 AM
oh lord here we go
[/QUOTE]
