Want to get rid of the EBPV butterfly valve! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-07-2009, 12:35 PM Thread Starter
I recently put a new turbo pedestal on my 02 from garrett that deletes the ebpv. The problem I had immediately was that the butterfly valve was still closing about half way and wouldnt re-open. I would have to manually open it, so I ended up using strong steel wire to hold the butterfly valve open. My question is, is there any turbo housings or anything that can be put on to replace the housing that has the butterfly valve inside it, I want that thing gone, it is nothing but a headache?
Any ideas, please let me know...much appreciated
mthai3 is offline
post #2 of 9 Old 01-07-2009, 01:02 PM
What u talkin bout willis
REDPOWERSMOKER's Avatar
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
IS THIS WHAT YOUR LOOKING FOR?
Beans Diesel Performance - 99-03 Power Stroke Van Turbo Adapter Flange (Powered by CubeCart)
2005 F-250
Tuned by Innovative
Deleted by Performance Machine
Coolant filter (Orderd) by Performance Machine
REDPOWERSMOKER is offline
post #3 of 9 Old 01-07-2009, 02:12 PM
harrys91rs's Avatar
Send a message via AIM to harrys91rs
I got my "high flow" outlet from itp, bolts right up to the stock turbo or the 38r.
High Flow Outlet
Also, I think i read something on removing the valve out of the stock housing, this would be the cheapest. I guess you have to plug some holes that removing the shaft of the valve leaves.
2000 F250 7.3 SCLB 4x4
DP Tuner, Bean's Stage 2's, 38R, BTS, K3LA Train Horns
Best 1/4: 13.77 @ 97.19
Best 1/8: 8.72 @ 78.67
448Hp 904Tq
harrys91rs is offline
post #4 of 9 Old 01-07-2009, 05:24 PM
99sd's Avatar
you could take it out and have some weld the holes... i think it is cast metal
"The only thing that runs on a cummins, is the owners mouth!"
"That smoke doesn't mean it broke"
99sd is offline
post #5 of 9 Old 01-08-2009, 07:12 AM
layson's Avatar
Quoted: 82 Post(s)
Just grind out the rivets or welds for the flapper... then remove the rod that holds it and plug it with a freeze plug. It isn't quite the same as the high flow outlet. The high flow outlet is a touch larger...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #6 of 9 Old 01-08-2009, 09:42 AM Thread Starter
thanks everyone for the input im going to look into those ideas
mthai3 is offline
post #7 of 9 Old 01-08-2009, 04:17 PM
77 powerstroke's Avatar
whats this butterfly valve is that the valve that makes the truck warm up faster
2000 f-350
Dp-tuner modifstock-100perf-140 extre
custom cold air intake/stage 2 diy injectors
5in mbrp stacks
33in allterrains 4in skyjackerkit
77 powerstroke is offline
post #8 of 9 Old 01-08-2009, 04:28 PM
Ole White
bigwhite7.3stroker's Avatar
Yes its the warmup valve
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #9 of 9 Old 01-08-2009, 08:28 PM
Captain Starbucks's Avatar
Just throw down on the ITP hi-flow exhaust outlet. I think it's $120 or so. Never again will you worry about that valve closing and it'll cool it down just a bit on the EGT guage. Mine went from about 600 before I got the valve to about 550 or so after (at freeway cruise, unloaded). Not a huge drop. It also seems to spool a bit quicker. You'll see why when you get the hi-flow valve in your hands.
2001 F-250 7.3 4WD CC LB,SB CON OFE clutch, DIY 6637 intake. Superior compressor, 4"SS Magnaflow
DP-Tuner:Hi idle,60T,80T,80E,120. Diprocol boost/pyro. Overboost Annihilator. Hi-Flow turbo outlet.
4" Superlift. Springs/blocks w/ Bilsteins. 315/75-16 Toyo M/T's. 35" spare underneath. Truetrac
Alpine deck, Infinity 6x8's, Kicker Comp 10", JBL 6x60 amp, 1.2 MFD cap.
Glasstite High Rise Cap. 7,800 empty weight.
Captain Starbucks is offline
