update on noise~~HELP! - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-06-2009, 11:59 PM Thread Starter
RedDye01's Avatar
So I've posted on this noise before. Its a faint rattle that is coming from behind the dash. It sounds like someones shaking a ping pong ball inside a soda can. Sometimes you can hear it, sometimes you cant. Its been getting colder lately and its getting louder. It seems to be coming from right behind the dash on the drivers side. I can hear it most when i shut the truck off. It seems like it rattles for a split second after the truck shuts off and thats about the only time I can hear it well enough to tell where its coming from. If i stick my head down by the fuse panel and shut it off I cant hear it. If i stick my head by the master cylinder under the hood and have someone shut it off i cant really hear it. I hear it best when i stick my head by the gauges and listen and kill the motor. Heres the new development. It rattles as im driving and when i come to a stop it continues to rattle. The colder the engine the more it rattles. If I push down on the brake hard while im stopped, the noise stops. When i lighten up a bit, it rattles. If i keep pushing down hard, and letting up the noise stops and starts every time i let up on the brake. Any idea? could it be the brake booster? master cylinder? could it be the brake at all and when i mash hard on the brake could it just be putting a load on the engine that stops the rattle?
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
post #2 of 11 Old 01-07-2009, 12:02 AM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
Could be a loose bolt or something on the brakes. Go around and check em all.
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 11 Old 01-07-2009, 12:12 AM Thread Starter
RedDye01's Avatar
theres no noise from outside the cab though. its only on the inside. ideas?
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
post #4 of 11 Old 01-07-2009, 12:13 AM
scuffs *****
Tyler's Avatar
idk brother, someone else will need to chime in. Sorry!
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #5 of 11 Old 01-07-2009, 01:21 AM
regor's Avatar
Check all the connections from the pedal to the back of your booster, something may have loosened up on you.
Roger
2006 F250 Superduty 6.0L 6 speed manual
MODS
Banks with PDA, Iron Horse Bumper,Upfitter switches, High Idol Mod, Zoodad, Tint, K/C Lights, 08 F250 Rims, Remote start and Viper Alarm, 03 Turbo, Electric exhaust cutout, ARP Studs and EGR Delete Thanks To Scott @ Trucks Unlimited
Coming Attractions
SCT Custom Tuning
regor is offline
post #6 of 11 Old 01-07-2009, 01:23 AM Thread Starter
RedDye01's Avatar
ill check in the morning. the master cylinder wouldnt make noise would it? i mean if it were getting ready to call it quits?
Bellowed Up Pipes
GTP38R
T500 HPOP
HPX Line
RiffRaff FRX Line
JW Valve Body
4" Lift w/33's
6637 DIY intake
4" exhaust
Gauge
RedDye01 is offline
post #7 of 11 Old 01-07-2009, 01:28 AM
regor's Avatar
Not that i have ever seen, but the linkage rod that goes up to the back of the booster could be loose causing a noise.
Roger
MODS
Coming Attractions
SCT Custom Tuning
regor is offline
post #8 of 11 Old 01-07-2009, 07:04 AM
Austinj427's Avatar
maybe someone fooled you and put a soda can with a ping pong ball inside it somewhere in the dash
Austinj427 is offline
post #9 of 11 Old 01-07-2009, 08:27 PM
rsecondchance1's Avatar
Send a message via Yahoo to rsecondchance1
Check your body to frame bolts or a shock bolt. Just a thought as when the engine shuts off it rattels the truck a little. And it sounds like it may be getting looser.Good luck
2000 F-350 XLT Super Chips Stage 2,DFuser 18k Mod, Wicked Wheel ,self made air intake,CCV Mod, Oil Cross over,Trans Command,Rancho 9000,2 inch front lift with 1500lb add a leaf,5000lb rear air bags,315/60/17's, Magna Flow Shorty,JVC HD39, 800 watt amp door speakers, 600 watt amp 12 inch sub,linex bed linner
13000lb Raptor 3600 RL Toy hauler, just for the pull
Play Hard,Drive Hard,Ride Hard
If not Stay Home
Powerstroke and KTM for a rush
rsecondchance1 is offline
post #10 of 11 Old 01-07-2009, 08:58 PM
It isn't the downpipe is it?
Diesel Monkey is offline
