Wipers wont stop - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-06-2009, 01:12 PM Thread Starter
Wipers wont stop
I have an 02 350 7.3 tried starting one cold morning, but the batteries didn't have enough juice. When i stopped cranking the wipers came on and they wont shut off. Is there a relay stuck or a switch of some sort?
crazydrivers3 is offline
post #2 of 6 Old 01-06-2009, 01:15 PM Thread Starter
I have tried pullling the fuse and dissconecting the batteries but it didn't help the situation.
post #3 of 6 Old 01-06-2009, 01:24 PM
It sounds like the relay. Open the power distribution box and pull the relay. That should stop them. Last relay I bought from Ford cost around $10. If you want to do a quick check, change the relay with another one just like it in the box.
Jrsummers is offline
post #4 of 6 Old 01-27-2009, 01:38 PM Thread Starter
Not sure what relay it is. I pulled them all out and they still don't stop. The only thing that will stop them is pulling out the the fuse. Any other Ideas? Thanks...
post #5 of 6 Old 01-28-2009, 07:18 AM
It sounds like one of 3 things. 1- the park in the motor is shot. This is what stops the motor in the same spot when you turn it off. This means a new wiper motor. 2- The switch is shot or broke internally and the switch will not open to turn off the motor, need a new switch. 3- The wires are touching some where in the harness and over riding the switch.
As a note, I would not do anything until you use the owners manual and confirm you pulled the right relay. There is a fuse box and a power distribution box. Check both. Most of the time either on top or under the lid they usally have every fuse and relay marked.
Jim
post #6 of 6 Old 01-29-2009, 10:14 AM Thread Starter
Thanks for the info there is a pulse board on the motor. it is shot and I have a new one coming.
