HEATER MODE SELECTOR CONTROL will only work in the defrost mode. I Need a fix.
More than likely you have a vacuum leak somewhere.
I agree with Ford Trck, check your lines from your front hubs, they decay and crack after a few years. replaced mine 2 times, ordering the stainless ones next time.Good luck
Stainless ones?? Please elaborate with a source
I've seen many on our web site here is one to look at. There are many more some will replace the metal fitting on the hubs as well. If I find more I will post the latter.
http://www.amazon.com/Spectre-19298-.../dp/B0006305LU |
Nice......adding to mod list
Mine did the same thing , it was the electric vacuum pump on the passenger side inner fender behind the starter relay, about 116, Bucks at ford and everything worked fine.
How did you check your electric VAC PUMP?
I pulled the hose off mine and nothing. My guess is I should have something or even hear the motor when the ingition is on and truck is off right?
