Adding Oil to Fuel????
Got a call today from a friend who said he was fueling his Truck in Southern Virginia and the Mechanic said he was suggesting owners of older (2006 and prior) to add a quart of oil to the fuel when filling up. Said the Low Sulfur content has reduced the lubrication abilities of the fuels since 2007. I told him not to do any such thing. But, said I would post it here for input.
I occasionally include LUCAS or another brand of treatment occasionally to keep the system clean as can be. Question: If this bulls&#t or what? Tom 99.5 7.3 PSD 150k and counting - only a Water Pump so far... |
I add an additive due to my engine telling me it sounds quieter.
SOOoooooo when are we gonna get a choice at the pump like gasoline burners do? |
I've never done it, but I've seen a few posts about adding 2 stroke oil to the fuel, or a product like DieselKleen... I just bought some of the DieselKleen a few days ago, gonna try it, see if it changes the idle chatter and ease of start up, and also the fuel mileage...
I would guess that the type of oil would make a diffrence, I hope others who know more than me will advise... |
I haven't tried it but i have read every thread on it and the people who do use it swear buy it but there is a ratio of 1oz to 1gal and it has to be ash less two stroke which is marine two stroke.
I add 1 once per gallon(2 stroke ashless) every other tank.It does quiet the motor down alot,nothing much on the mileage to speak of.
i do one ounce per gal. of TCW-3 2 stroke outboard oil. it has to be marine ashless if it says TCW-3 your good to go. it runs better and makes it a little quieter
If you do add oil it has to be ashless 2 stroke oil. Any other types of oil will cause injector damage. It has been known to quiet the injectors. But not much if any fuel mileage increase
So there is partial truth to what the mechanic said. The ULSD was little lubricity and can use some help. But adding oil is a bit much in my mind. Will it burn? YES. Can it clog or damage injectors? YES. |
A friend of mine has run around 30-40% used filtered motor oil when the fuel prices were real bad. I wasn't that desperate though...
