How to Break-in?
So is there a way to get in a locked crewcab without breaking anything?
![]() ![]() Fing auto door locks. |
Oh and it has sliding back glass.
you can pop the back glass with a screw driver and your in. its hard to describe but I have done it before i put my Cab rack on.
A big one or a little one? I tried a knife but it was a crappy one and the blade kept flexing.
I used alittle one, put it in with my right and, and pushed in a bit with my left, which allowed it to clear the latch, carefull not to break it tho
Use your antenna put a 90* bend in it about 3 inches from the end. Drop it in the door lined up with the inside lock. Slide it into the door and turn it untill it hits the rod connected to the lock. You will see the lock button on the top of the door jiggle as you tap it. continue down to slide the antennae into the door untill you end up under the bend in the rod. Then pull it back up.
And when it did then I did what you said and no luck.
Ive used a wedge,screwdriver and a rag at the top of the passenger door with a hanger many times. Just shoot for the power lock button. The slider window trick works but I have busted a window with the slightest pressure and it wasnt cheap to replace.
Wedge??????
