Use your antenna put a 90* bend in it about 3 inches from the end. Drop it in the door lined up with the inside lock. Slide it into the door and turn it untill it hits the rod connected to the lock. You will see the lock button on the top of the door jiggle as you tap it. continue down to slide the antennae into the door untill you end up under the bend in the rod. Then pull it back up.:thumb:
Ive used a wedge,screwdriver and a rag at the top of the passenger door with a hanger many times. Just shoot for the power lock button. The slider window trick works but I have busted a window with the slightest pressure and it wasnt cheap to replace.
These are the easiest vehicles to break into. Pull up on the outside window trim on the door and the shaft for the door lock is right there. You can use a number of different tools/devices to pull up on that shaft thus unlocking the door.
I do this very often at my work. In fact I did it today, a little word of advise, if your gonna break into a jeep wrangler, just call a lock smith. But yeah the wedge thing works great. Push your block into it so it gets a gap. Drop the hanger down in and have someone guide you, or stand in the bed so you can see where you are goin. Push down and it will unlock.
Ok, Got a friend to call AAA since he was right down the road and he was trying to unlock it with a tool but was unable for 10 minutes. So he did it with a air wedge and a coat hangar.
ON my OBS I pot about a 45 degree bend on my antenna and stuck it beteen the door and the cab and hit the power doorlock switch to unlock it. It worked for me more than once.:thumb:
For future reference I hd a spare made at walmart (no chip so it wont start the truck but) and i mounted it behindtghe license plate putting one of the screws through the eye of the key and you can unscrew it with a coin out of your pocket in a time of need.
From Personal Experience: The coat hanger behind the glass to hit the power lock button from the top works great, I tore a little hole in my rainstripping but at least I got in.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
