still confused - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-31-2008, 10:10 AM Thread Starter
killa071's Avatar
Exclamation still confused
okay lately my truck has been acting up i will be driving and it will die and when i turn the key back on sometimes the wts light is on sometimes it wont be and if its not on then it wint start sometimes i wait it comes on and i can drive for a minute or a day before it dies again im going to change the cps and see if that helps and other input would be great thanks guys
2011 F350
mobile 1 5-40
killa071 is offline
post #2 of 9 Old 12-31-2008, 10:37 AM
layson's Avatar
Quoted: 83 Post(s)
does it start back up after it dies?
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 9 Old 12-31-2008, 10:46 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
that might be the cps
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 9 Old 12-31-2008, 11:01 AM
GoldieStroker944's Avatar
when my cps went out thats exactly what it did but it also did the almost exact same thing when the idm went out and then it moved onto running really rough and shaking really bad so i would start with the cps
2003 7.3L
Crew Cab Short box
Lariat
Cowl (functional)hood
315/75-16 wild coutry A/T's
Hypertech power programmer 3
T.S 6pos
stock,high idle,50,75,100,140
AFE stage 1
Foil delete
MBRP Cool Duals 6" tips
Sirius sat radio
GoldieStroker944 is offline
post #5 of 9 Old 12-31-2008, 11:11 AM
DOES THE TACH MOVE WHEN CRANKING THE ENGINE?
19558077 is offline
post #6 of 9 Old 12-31-2008, 11:14 AM Thread Starter
killa071's Avatar
okay so after it died the wts light didnt come so i was like just watching the lights and the tach started moving and jumped to 500 rpm then went to 0 cycled the key a couple times and it started but it will only start if the wts light comes on first
2011 F350
mobile 1 5-40
killa071 is offline
post #7 of 9 Old 12-31-2008, 01:07 PM Thread Starter
killa071's Avatar
well i changed the cps only time will tell now just gotta hope
2011 F350
mobile 1 5-40
killa071 is offline
post #8 of 9 Old 01-01-2009, 01:37 PM
WSStucker's Avatar
Ford actually had a recall on the CPS. I don't remember which years, but, I had just changed mine about a month before.
______________________________
2001 Excursion Limited 2X4
Zoodad, Marinco MOD, Rotella Synthetic
4" MBRP stainless turbo back, DIY Intake,
6 pos TW, Autometer trans-pyro-boost,
HP crossover tube.
** Newly added custom HYBRID tags **
2005 F550 Stock Company Truck w/ALTEC boom
WSStucker is offline
post #9 of 9 Old 01-01-2009, 10:35 PM
Ford has a Re-call on Cam Position Sensors from 94-2003 7.3 DI engines, I've had 2-3 in the shop for them in the last few months. Mine has yet to fail but I really should get it done.
2003 F250 Lariat 7.3L Crew Cab 4x4 SRW Short Box
Opened up front headlight bezel for better Airflow"ZOODAD MOD"
Airaid: Intake System 400-222
Tony Wildman: 6 Position Chip
Magnaflow: 4" SS TurboBack Exhaust
AutoMeter: "Z" Series- Pyrometer, 0-60 Boost, Transmission Temp
ITP: High Pressure Oil Crossover, Boost Annihilator
Innova: Turbo Lifesaver Turbo Timer
Soon To Have* SunCoast: Heavy Duty Transmission w\ Billet Input Shaft
Hades212 is offline
