Contribution/balanca test and injector buzz test
Can someone please elaborate on these. Id like to know whats all involved and required to do them and just exactly what all they test and tell u. Trying increase my knowledge on my truck for future reference.
Anyone? bump
need a good scanner for one that will do data and has a functional test ability
the injector buzz test is usualy done when you have a skip, and usually a check engine light with it , it tests the idm and and injector wiring to the injectors as well as the electrical part of the injector cylinder contribution is usualy done when a engine is skipping , check engine light or not , will pinpoint , bad injector , low compression on a cylinder , anything that will cause a skip and tell you which cylinder or cylinders are skipping no reason to even run these tests unless engine is skipping |
I can do it for ya if you need it, just hit me up when you need it done.
I need one done.Mines been running on a few injectors short lately and its getting annoying .What is the cost to have this done usually?
Thanks alot man. My truck has had a surging problem lately and Im hoping Ive got it figured out and its not an injector or anything. Will a bad injector/s cause an intermittent idle surge? I didnt get any codes and theres no cel on.
Just give me a call... I can use the AE to test it out.
You travel maintain? I am in Raleigh, NC and need 2 excursions tested.
