Turbo questions - Ford Powerstroke Diesel Forum
Old 12-28-2008, 10:01 PM
Turbo questions
I have heard that you can put i 99 1/2 and newer turbo on and OBS, is this possible? If now why? If so what do i need? Will it ad anymore power? Guy told me since it was a non external wastgated turbo it would bolt right up. He had one on a 96 with stage two stick and a good tuned chip and made 380horse. I have a 2000 in our junk lot see if this will work before i want to ask the guy if he will sell the turbo. Also if they do bolt right up could i just swap the two mine for his, the opposite. thanx for all the help
Old 12-29-2008, 03:21 AM
Come on now need some help!!
Old 12-29-2008, 04:13 AM
Ole White
Yes you can if you have a 2000 7.3 just sitting there to rob parts off of.
You would need the following
Turbo and Pedistal
Up-Pipes
Intake Spyder
the intake manifolds(were the boost tubes go into the motor) the SD ones are larger
Intercooler and (IC tubes would have to be modded for the OBS or buy the kit)
Old 12-29-2008, 04:15 AM
Ole White
Can you guys think of anything I'm missing??
Old 12-29-2008, 04:16 AM
Ole White
did mean to post again
Old 12-29-2008, 01:38 PM
ok well this van is none intercooled so wat do i need of of it
Old 12-29-2008, 05:32 PM
Old 12-29-2008, 06:22 PM
PMR = JUNK
Everything he said except the IC stuff.
Old 12-29-2008, 06:25 PM
There are kits to bolt them on too. if you dont have the parts
Old 12-29-2008, 06:34 PM
Can anyone give me some numbers to see if the is worth it dont want to go through all of it if its not worth while?
