tranny leak? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-28-2008, 03:58 PM Thread Starter
tranny leak?
Whats up in the front of the auto trannys that can leak? Front seal?
Is their any sort of drain plug in the convergter? I have tranny fluid around the bell housing plug in the bottom. (at least looks like a site plug or something?)
Iam thinking only front seal would leak here??
thanks
melmount is offline
post #2 of 5 Old 12-28-2008, 04:05 PM
psd
yes your TC has a plug in it the only thing that could be leaking would be trans pump seal or shaft is not setting right in the TC or trans it self.
outlawdiesel is offline
post #3 of 5 Old 12-28-2008, 04:16 PM Thread Starter
I get the front seal, the shaft? like play in it allowing fluid to get by?
Does the TC plug ever leak? if so can I get to it?
thx
melmount is offline
post #4 of 5 Old 12-28-2008, 04:24 PM
psd
yes take the cover off the trans it should be 4 10mm bolts and it will come off then you can get to the plug on the TC. the Tc is full.drain first
post #5 of 5 Old 12-28-2008, 04:30 PM Thread Starter
thanks, I am not going to remove the plug unless its leaking.
melmount is offline
