slight concern - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-28-2008, 12:46 PM Thread Starter
Austinj427's Avatar
slight concern
Changed the GPR in my truck last night and did the oil as well. My dumbass tried to chance the HPOP oil as well and I dropped a small rubber hose in there. After staring at the setup for a while I was able to take it apart, take out the hose and put it back together.. My only concern is that it is ALOT more quiet now.. Is this a good or a bad thing? Im afraid I screwd up something in the HPOP and now it is running a lower pressure or something.. Some feedback from the experts would be nice
Austinj427 is offline
post #2 of 6 Old 12-28-2008, 12:59 PM
dmd
dmd's Avatar
Just changing the oil will make it much more quiet. The new oil up in the injectors and
HPOP does that. Changing the oil in the HPOP didnt do anything except get a few more
ounces of the oil motor oil out.
If you messed up the HPOP it wouldnt want to run at all, or when getting on the throttle
it would set a SES light with low HPOP oil pressure.
My truck sets that code when pulling my 10k TT and running Tony's Tunes....
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, 6-pos Chip, 6637 filter, 4-inch turbo back exhaust, Garrett 38r w/ high flow outlet, ITP overboost eliminator, AIH delete, Adrenaline HPOP, BTS Trans, Swamps IDM, In-tank & Pre-Pump mod, Heater Valve mod, X-car Sound Pannel mod, Train Horns / Packages: Trailer Tow, Camper, Off-Road. Overhead monitor DVD/TV/VCR (VCR under rear seat w/ 6 CD changer)
(Offroad riding in California)
dmd is offline
post #3 of 6 Old 12-28-2008, 01:11 PM Thread Starter
Austinj427's Avatar
Ok good to know thanks man.
post #4 of 6 Old 12-28-2008, 01:18 PM
Blowin Smoke
firemedic355's Avatar
Just for my own knowledge, doesn't your new motor oil filter into the HPOP anyway? So is it really very beneficial to worry about changing it if I keep up with my oil changes?
99' F250 Ext Cab Flatbed 4x4
EDGE Juice w/ Attitude
Cowl Hood
Warn 12000 winch
Warn hubs
Billet Grille
DPF Delete
CCV Mod
4" lift w 35's
5" black single stack
firemedic355 is offline
post #5 of 6 Old 12-28-2008, 01:24 PM Thread Starter
Austinj427's Avatar
Im not really sure about the 6.0. But i have heard it is a good idea to change it with the 7.3.. But its a pain in the anus without a pump.. I used a hand syphon.
post #6 of 6 Old 12-28-2008, 04:41 PM
NYMustang50's Avatar
Alright... Yes the oil and the oil in the hpop do mix/drain into each other. But its over a very long period of time like a long long time... Thats why when you change your oil just the oil it will still sound the same but if you change the oil and the oil in the hpop you will notice a difference. Its not a wasteful thing to do I would do it every other oil change but thats me. But they do end up mixing at some point.
NYMustang50 is offline
