Wastegate Question
So what happens if I unhook the red vacuum?? line to the wastegate?? What is the effects, what will it hurt, what can I gain? Just wanted to know. Still learning!? Oh yeah, what can also cause the SES light to come on when I accelerate from about 30 to 65/70 coming on an on ramp, grade, hill, etc? Sometimes it comes on and will go out a little while later, and sometimes it won't go out till I shut off the truck and restart it!? Thanks for the help
Anyone help me out on this one? It sure would be appreciated!
is it throwing any codes
Don't have a tool to pull the codes, and being stationed here in Key West (Navy) not any parts store that can or will help out with a scanner. So give me a guess or anything that might help. Truck is a 2001 f-350
i dont know if yalls trucks have a fuel filter light but mine does and before i changed the fuel pump i could rev it up in neutral(for a smoke show) and the fuel filter light would come on. maybe you have a clogged fuel filter or a bad fuel pump. just a guess
Your check engine light sounds like an overboost code. Do you have a chip, programmer or module installed? Did you unhook that red line when it did this? Unhooking that red line will make the computer unable to control the boost. I wouldn't recommend this if you don't have a boost guage installed.
If you have a 10k mod, that could explain why you get the SES light underheavy acceleration. If I have my defuser 18k turned all the way up I will sometimes have the same thing happen. I too have my red line unhooked and struck it on one of my intercooler clamp bolts, so it can still pull vacum. When I go over 24psi. I also get the overboost code, and SES light.
Did the same thing before and after I did the 10k Mod. and with or without the waste gate vacuum disconnected. So I guess I am still chasing my tail. Fuel filter was just changed a month ago. I am doing the fuel shim mod this weekend. So maybe that might help?!
Anyone else have any thoughts on this one? Really could use the help. New and still learning the ins and outs. But love that deisel power.
Anyone else have any inputs on this one? Thanks guys
