Gauge Pod Installation ??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-27-2008, 09:45 PM Thread Starter
Exclamation Gauge Pod Installation ???
Hi ! i just bought a three gauge pod that goes on the left pillar beside my windshield, can anyone plz help me with the installation, how can i make it hold there tight ?
Thanks !
cummins eater is offline
post #2 of 11 Old 12-27-2008, 09:54 PM
20stroker02's Avatar
Your local parts store should have some interior screws that should hold it, I had to do this on my OBS
2011 F350 CC/SB Ultimate Lariat FX4, Black on Black
Leveled w/37" Nitto Trail Grappler
20" Badlands
USMC
20stroker02 is offline
post #3 of 11 Old 12-27-2008, 10:00 PM
Raul@Stealth Automotive's Avatar
it should of came with the screws to hold it in place....
Raul@Stealth Automotive is offline
post #4 of 11 Old 12-27-2008, 10:16 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
you should have to drill 4 small holes in it and then put these little plugs in them to hold the two together.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #5 of 11 Old 12-28-2008, 07:46 AM
Powerstroke Junkie
NCHornet's Avatar
You do understand the gauge pod is just a overlay, it fastens to the old a pillar trim piece, you drill holes in it to pass the wires through.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #6 of 11 Old 12-28-2008, 08:11 AM
Powerstroke Techie
alabamafrog's Avatar
I have installed several sets of gauges and I always remove the factory pillar and save it incase there is a need to put it back stock later. I install 1 screw in the top of the gauge pod and screw it into a metal lip in the roof area, being careful that the screw isn’t long enough to go too deep. I have drilled and tapped for a 10-32 and I have used a self tapping screw. This works well, saves the stock pillar trim, is quicker and easier to do that cutting up the stock trim, is easy to access or remove in the future.
You can see the silver screw in the top left of this pic;
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #7 of 11 Old 02-26-2009, 08:26 PM
builtnotbought's Avatar
Thanks for the pic !
builtnotbought is offline
post #8 of 11 Old 02-27-2009, 07:42 AM
superduty4x4's Avatar
I bought an extra A-pillar on Fleabay for $10 and saved my stocker so that if I ever sell the truck and want to keep the gauges I can without leaving huge azz holes in everything. You could probably grab one from a junkyard for that much cash or less- color doesn't matter, just shoot it with the same paint you use on the gauge pod.
Diesel Manor has a very complete set of instructions on installing gauges, the online version isn't quite as detailed but will surely help you out- clicky.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 11 Old 02-27-2009, 09:21 AM
CSIPSD's Avatar
I have had 5 PSD's from 95, 96, 97, 99, 01 and everyone of them has had gauges installed... When I sell the truck the gauges have always been left inside....
New truck, I want new gauges... IMHO overlay the stock piece and be done...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #10 of 11 Old 02-27-2009, 02:12 PM
91turbogsx's Avatar
A stock a pillar trim from Ford new isn't that expensive. I just bought a pre-assembled one from ITP and was done with it (which comes with a factory A pillar with the pod overlayed already.) And I still have my stock one.
And I must say Dennis did a helluva job. Looks factory, barely even see the plastic rivets and the paint is perfect.
'02 F-350 Powerstroke Standard Cab/Long Bed
I got a bunch of crap on it....
91turbogsx is offline
