Corner Lense Removal Help...
what is the best way (by that i mean easiest) to remove the passenger corner lense? The bulb burnt out and the driver side headlight blew out (the bulb is shattered inside the housing...). Headlight is the easy fix, but do I have to pull the passenger headlight to remove the corner lense? If thats the case I suppose the battery is coming out too.
subscribed
Yes pulling the headlight comes first, you will need to pull the battery, those clips are a real pain, the easiest way is to just unscrew the adjusters all the way out, there are two screws under the corner light and then you pull hard straight out to get it loose.
NCH |
so, pretty much got everything done today that i wanted.....corner lense removal was easy, it was just 2 screws on the bottom (in the gap in between the top of the bumper and the bottom of the lense), then just pull and out she came
if you plan on removing yours nsrchofpwr, just remember that after it pops loose you are only gonna have a couple inches of room to move it around...Ford doesn't give much slack |
