HELP!! my 2000 7.3 excursion turns over but wont start
it was running fine this morning went to work no problems at all when i went to leave work turns over very strong but wont start it's getting fuel and has new fuel filter
did you check your cps
yes i had a spare one so i changed it just to make sure thanks
check the fuses under the dash, sometimes they can come lose and cause a no start.
i checked them . but someone was saying something about the fuel bowl heater
yea check your #30 fuse it's your fuel bowl heater/pcm fues but if it's out you won't have a waite to start light
my light is working
Its a 30 amp fuse under the hood. the one farthest fron the fender.
whats the temperature where your from? Bad glow plugs? harness?
If you are sure it is getting plenty of fuel, unplug the ICP and see if it will start, if there is oil on the connector it is bad.
NCH |
