PLEASE HELP!!! I THINK I BLEW MY TRUCK UP - Ford Powerstroke Diesel Forum
Old 12-26-2008, 06:33 PM
Send a message via AIM to bignasty250
well, i guess i messed somethin up. iwas goin down the interstate today and a 6.0 tried to race me, i ended up racin him and we got up to about 110 so i let off so i wouldnt mess anything up. i started slowing down and the motor was runnin fine until i hit about 75 and it shut off, it wasnt knocking, running hot and it didnt lock up. i pulled to the side of the road and when i stoped it was pourin oil right where the motor and tranny couple, it was about 2 quarts that came out. i looked around the heads and there was no traces of oil or coolant around the gaskets but the was a little puddle on top of the motor and there was oil around the turbo. what could i have messed up??? please help me with this and also the motor will not start and it is not making any out of the ordinary noises.
Old 12-26-2008, 06:38 PM
sounds like you blowed and oil line off some where
Old 12-26-2008, 06:54 PM
Sounds like a HP oil line to me. The hp pump is right on the front of the motor on top. I have seen the lines blow and then it goes back the valley and there is a drain hole where it will run out right where you are talking. No high press oil no start. The injectors don't have the oil to run the spool valves. I am no Tech so this is just my theroy. I have been wrong before. Get up on top of the motor on the driver side front is your high press pump. Look @ the lines off of it, may have blowed a o ring on one of them.
Old 12-26-2008, 06:56 PM
Does it crank? Try turning the motor with a 1/2 in breaker bar and socket on the crank pulley does it move?
Old 12-26-2008, 07:39 PM
it turns over fine
Old 12-26-2008, 07:46 PM
so the starter works then.. sounds like dusty might be right i would check find out where that oil is from because it sounds right that if theres no oil up top in the hpop then it wont start....
Old 12-26-2008, 08:02 PM
Rob Rob is offline
check those lines...
Old 12-26-2008, 08:05 PM
Pointless Poster
deffinently a line. to much pressure. 7.3's dotn like 100+ lol
Old 12-27-2008, 12:18 PM
what they all said it sounds like hpop line and isnt the hpop resavor about two courts?
Old 12-27-2008, 01:19 PM
The Screwy HEUI
1qt. in the res., 1qt. in each head.
