4wd relay location? - Ford Powerstroke Diesel Forum
Old 12-26-2008, 02:00 PM
4wd relay location?
I can't find where the 4wd relays are. My 4wd is not working and all the fuses are good, and everything is plugged in but still nothing.
Any help would be awesome!
Old 12-26-2008, 02:48 PM
Powerstroke Junkie
There is a switch for the TC on top of the transfer case. Mine came loose one time, still can't figure out how it came undone!!
NCH
Old 12-26-2008, 02:50 PM
I'll check that too, do you know where the 2 relays are located? In the owner's manual it lists them, but does not show a location.
Old 12-28-2008, 08:31 PM
Come on, nobody?
Old 12-28-2008, 08:43 PM
Send a message via AIM to harrys91rs
My manual says "LH side of engine compartment, near battery junction box" for the high-to-low relay and low-to-high relay.
Old 12-28-2008, 08:49 PM
Yeah there are 2 banks of relays other than whats in the fuse box. Both banks have 2 relays in it.
Old 12-29-2008, 07:19 AM
Morning bump
Old 12-29-2008, 09:51 PM
Another bump...
Old 12-30-2008, 12:08 AM
If you have a owners manual it should show you where the fuse and relay locations are and tell you what is what. If you don't have an owners manual then you can download one for free from here https://www.fleet.ford.com/maintenan...ls/default.asp
Old 12-31-2008, 08:32 PM
Well I got it to work. I pulled and cleaned the connectors on the transfercase. But I still would like to know where the 2 relays are.
This is what my book says.
