powdered metal rods - Ford Powerstroke Diesel Forum
Old 12-24-2008, 07:30 PM
powdered metal rods
what year did the 7.3 switch to the powdered metal rods, are these better than the previous or worse?
Old 12-24-2008, 07:33 PM
half way thru 2001 I think. Heres a bump for you anyways.
Old 12-24-2008, 07:38 PM
PMR = JUNK
Late 2000 was when they switched. 2000 model year trucks built in 99 usually had forged, later 2000s, some had PMR's, some had forged. I think all 2001 and on are PMR. And the PMR's are worse. Bad. They hold stock power ok, but if you do much upgrading they will crack. Forged are good for about 500 HP reliably i believe.
Old 12-26-2008, 09:19 AM
International Threat
10/2000 was when they switched but there was a series of trucks that came with forged rods into 2001 when the PMRs were not supplied for a few weeks. The ONLY way to know for sure is to pull the inspection plug and check for yourself. Bolt = bad, nut = better.
Old 12-27-2008, 11:53 AM
...and where is the inspection plug?
Old 12-27-2008, 11:55 AM
7.3 Inspection Hole for Powdered Metal Rod Determination
Hope that helps
