quadzilla commander questions?? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-13-2006, 03:44 PM Thread Starter
I just intalled my quadzilla commander and have a couple of questions. What whould the boost read at idle. I read 1 psi at idle and engine not running. Is there something wrong? What whould I set the alerts at? What should water temp be at normal operating temp? I have a dfuser and I want to make sure that the engine is at normal operating temp before turning it up.
1999 f250 superduty PSD.
tymer intake
4" MBRP exhuaust
superchip programmer
3" lift
dfuser 18K module
quadzilla commander
dieselbop is offline
post #2 of 5 Old 12-13-2006, 04:07 PM
The Fat Mod
Logan's Avatar
Be sure to set it up for your truck. Go into set up and select truck I belive. Then it will give you a number of trucks to pick from. I think they are set for a dodge from the factory. Your water temp is actually an Oil temp. There should be an update for that very soon. Just to change the wording. I belive mine ran around 180, but I dont remember for sure. I set my EGT alert at 1200, just so it would be a little early, and I would know that I had a little time to get out of the go pedal. But, that should get ya going. Anything else, just ask.
Logan is offline
post #3 of 5 Old 12-13-2006, 04:14 PM
<<---"Shadow"---
sea71's Avatar
He pretty much covered it. If ya still have issues with the unit, call Quadzilla. They have shown SUPER customer service.
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #4 of 5 Old 12-13-2006, 04:49 PM
im fat and ugly
stump0331's Avatar
hey bop
u dont have anything to worry about, just make sure your unit is set for your truck like brrs said
mine at idle and off read:
egt- ive seen it in the 70's
boost-0
oil-104
water-180
these are just the bottom numbers that the unit is set at as soon as the temps or boost exceed these the #s will increase
hope this helps
2004 Excursion
stump0331 is offline
post #5 of 5 Old 12-14-2006, 05:34 PM Thread Starter
thanks for the input guys. What should my coolant temp be at normal operating temp before I kick my dfuser 18k mod in?
tymer intake
4" MBRP exhuaust
3" lift
dfuser 18K module
quadzilla commander
