early 99 air intake tube - Ford Powerstroke Diesel Forum
Old 12-23-2008, 08:40 PM
i was just cleaning up the engine bay and thought id take off the spider and all the couplers and clamps and clean them a bit. then i noticed a large crack in the air intake tube that connects from the filter to the turbo compressor. so i took it off and it looks like some one just sawed right through it.
my question is...is the early 99 different from the rest of them?
also i guess this would be a good time to do the ccv mod, huh? so i just rotate the thing on the valve cover then run a hose to the ground?
Old 12-24-2008, 01:23 AM
Pretty sure I have one if you need it. You can have it for the cost of shipping.
Old 12-24-2008, 07:19 AM
awesome, i sent you an email rpm. thank you
Old 12-24-2008, 07:30 AM
a truck
To answer your question yes the early 99 is different, a 99.5-03 will not work on your truck only an early 99 intake spider will fit
Old 12-24-2008, 07:34 AM
as in spider do you mean the aluminum piece that sits in front of the turbo? or do you mean the plastic black tubes from the air filter to the turbo?
Old 12-24-2008, 07:35 AM
a truck
by spider I mean this
Old 12-24-2008, 07:37 AM
alright, sorry new to some of these terms. the thing that ripped on my truck is the black rubber intake tube from the ccv section to the turbo inlet (from the air filter)
Old 12-24-2008, 07:39 AM
a truck
Oh ok so just the turbo inlet pipe cracked then I see, thats pretty common for those to wear out. there are some places where you can buy and upgraded on from
Old 12-24-2008, 07:50 AM
alright rpm is positive he has one as well. i searched for a while last night and only found places that sell replacements for the first section ( the air filter to the ccv sleeve), not the ccv sleeve to the compressor.
Old 12-24-2008, 08:09 AM
a truck
Yeah Im not sure on where to get one for an early 99, I know where to get one for an OBS but that doesnt help, but if he has I would grab it up cause they are a ton of money to get one from a dealer
