Cold Start - Ford Powerstroke Diesel Forum
Old 12-23-2008, 08:13 PM
Cold Start
Hello All,
I just wanted to get some opinions on my batteries. I have been having cold start issues with my 2001 7.3. I cycle the glow plugs a couple of times, but with it being cold 28-36 degrees the truck does not start. I am able to crank the truck two or three times and then it is dead and I have to jump start the truck.
I wanted to know what was the normal cranking time or how many cranking cycles I can expect from my batteries. I have a feeling that my batteries probably need to be replaced. But let me know your opinions.
I don't have any problems if the truck is plug in for eight hours or so and I have check the GPR and it is getting power when the key is turned. So it could also be the glow plugs themselve maybe.
Thanks!!
Old 12-24-2008, 12:28 AM
Same here....crappy N. Texas weather has been kickin my early moring starting routine to around 20 minutes....
Be nice to see what everyone says here.
Old 12-24-2008, 02:12 AM
i just got an 01 7.3 and this is my first experience in cold weather with it. It usually turns over about 5 times then fires.
Over the past couple days (being 10-20 deg F and not plugged in) I've had a harder time starting it. I've noticed that after turning over more than 5 times, it turns slower and the bat. gauge drops a bit. On the next crank cycle, volts are back to normal for the first 5 or so turns over, then it drops again. Knowing it takes a certain amount of voltage to 'let' it start, I try not to turn it over much more than 5 or 6 times and concentrate more on heating the glow system.
My batteries are new and even though it slows down if I keep the key turned after the 5-6 times, the next time i try, it spins fast again for the first 5-6 cranks. I did this for about 10 min the other day and even though I thought I was killing the batteries, they held up fine and I got 'er started.
I think next time I'll give it two-three FULL glow cycles (leaving the key on for the full 2 min each time) before I try to crank it.
So, yes, it sounds as though you may need batteries. Also, be sure your running fuel additive and maybe a lighter weight crankcase oil for the cold months. I chose the rotella 5-40 syn for the New England winter. -so far, it's never failed to start (knock on wood)
Hope that helps.
Old 12-24-2008, 02:51 AM
WNY Biodiesel Co-op
check each glow plug
You need to check each glow plug for operation. My mercedes diesels will be hard starting if 1 or 2 glow plugs are not working . 8 working glow plugs will fire up a 7.3l with only a few short cranks with winter diesel and an anti- gel additive.
Old 12-24-2008, 05:21 AM
Lifetime Premium Member
If the batteries are crapping out that fast,I would think they are shot.I havent plugged mine in at all this year..lowest temp yet was 18* and it started right up.I put 2 new batteries in a couple of months ago(850CCA) and it made all the diff in the world.
Old 12-24-2008, 01:09 PM
Sounds like the batteries to me too. Starter could be dragging too. Dad had to put a new starter on his 99psd last year along with new batteries. Sounds like it is going to sling the flywheel out of her now where it cranks so fast
Old 12-24-2008, 03:18 PM
Powerstroke Junkie
Your batteries are dead, replace both of them, I just had to do this myself today!!! Then you need to check your GP's, follow the tech article in the Maintenance section. A properly working GP system should start the truck unassisted to 20 below.
NCH
