Truck wont turn/start
Prior to truck not starting:
Pulled a couple people out of the snow the night before. Drove with about 800 pounds in the bed yesterday. I dont think these two things would be the reason... probably because its negative 9000 degrees outside. (actually about 8 degrees) I drove around quite a bit yesterday. Came home, shut the truck off, went inside for 10 minutes, came back out and tried to start the truck. I turned the key and it turned over for about 2 seconds then wouldnt start. Now every time I turn the key in the ignition it wont make a sound. All lights come on and the battery is fine. Any ideas? Starter gone bad? Could it be anything else? Thank you! |
Check your cables and wires going to the starter and the battery, it could be a corroded cable that finally let go.
Even all the lights turn on?
