Ignition Chime - Ford Powerstroke Diesel Forum
Old 12-21-2008, 08:02 PM
Ignition Chime
I know this has been brought up before but I can't seem to remember what to do...... My door chime drives me CRAZY even when my key is not in the ignigtion it friggen rings and rings and rings and rings..........How do I stop this damn thing??????????????
Old 12-21-2008, 08:18 PM
Would it be the same for your truck as it would be for mine( 05 6.0)?
Old 12-21-2008, 08:32 PM
good question, I'm not sure, are you thinking the same thing about your chime?
Old 12-21-2008, 08:34 PM
No I deleted mine and if its this same this should get you right on track.
listen to radio w/ doors open?
Old 12-21-2008, 08:48 PM
I'll try removing the tilt cover to delete it completely without removing any fuses. Thanks for the info.
Old 12-21-2008, 08:50 PM
No problem and that is what I did, just taped it up
Old 12-22-2008, 06:13 AM
Thats Mr. Oil Leak.....
I pulled off the connection and taped it up and have had no problems since!
Old 12-22-2008, 12:21 PM
So is it ringing just when the door is open, or 24/7?
