tire question - Ford Powerstroke Diesel Forum
post #1 of 25 Old 12-12-2006, 04:14 PM Thread Starter
bignasty250's Avatar
Send a message via AIM to bignasty250
tire question
k wat tire would be the best for half road and half mud use sizes between 38"-40" im lookin at tsl's and boggers right now. also wat the biggest tire i can put on with a 8" susp. lift and 3" body with out rubbin or minor cutting
bignasty250 is offline
post #2 of 25 Old 12-12-2006, 04:16 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Do you like the super swamper SSR's?
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
post #3 of 25 Old 12-12-2006, 04:18 PM
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I ran 36" TSL SSR Radials and they worked pretty good. They SUCKED in the rain and wore pretty crappy. Also, if your going to see ANY snow, I wouldn't go with 'em. I'm running 35" BFG AT's and they are great. Good road manners and good offroad capability. They DO clog with mud but clean off with a stab of the throttle.
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #4 of 25 Old 12-12-2006, 04:43 PM Thread Starter
i dont like em at all
post #5 of 25 Old 12-12-2006, 04:47 PM
Slappy's Avatar
I sold tires for years. Depends on the rim size first, so you know what's available. After that I would see it there is a Super swaper SSR or a toyo MT that fit that rim. I dis ]agree with the BFG. I take more off and putt on the two mentioned above. I have run both and they rock the swamper I can't get in a 20xs38 so I run the toyo. Snow or rain they rock they both have aside biting tread and three stage lugs to help with sidewall traction and move the tire around if is digging to much or stuck. Both are wuite on the highway and will go 50,000 miles if you rotate once amonth(thank you Les Shwab) and don't smoke them everychance you get. Bfg,Buckshot,and the rest to skinny and to much side to side sway for highway use. Bad in the rain. Sorry but tires make the rig go and stop.
Slappy is offline
post #6 of 25 Old 12-12-2006, 04:49 PM
I really like the Toyo MT
post #7 of 25 Old 12-12-2006, 04:49 PM
Slappy's Avatar
most tires only wear bad if you don't rotate. And I mean rotate often.
Slappy is offline
post #8 of 25 Old 12-12-2006, 04:56 PM Thread Starter
hmm i like to smoke the tires lol but wich will hold up to that and do good in all situations like mud, rain and highway use
post #9 of 25 Old 12-12-2006, 05:02 PM
Slappy's Avatar
any tire over 35 with lugs is not going to like leaving it's tracks. tears them up, But both are good for the mud rain and highway open lugs the ssr has bigger solid lugs the toyo smaller. What size rims? maybe keep some old tires on spare rims for smoke shows. ha ha never run an AT tire unless you run two wheel drives and need a steering style tire like a semi., MT so it all these days since they are radials. Never run a bias ply unless it is strickly of road you will hate the ride.
Slappy is offline
post #10 of 25 Old 12-12-2006, 05:07 PM
I had a set of cooper street radials that would go forever on a burnout after powerbraking them loose, but I had a set of Goodyear MT/R's that would break loose after powerbraking, but would bite pretty quick. Goes to show how much softer the tread was on the mtr
