What happened to my mileage????? - Ford Powerstroke Diesel Forum
Old 12-19-2008, 08:22 AM
Guys, does the change to "winter blend" really cut into MPG's? I was getting about 330 miles between fill-ups and now I'm lucky to get 250. It seems the last 2 tanks have just sucked.... my driving habits have not changed at all, I've towed nothing and have no upgrade / mods on my truck. Could I have something else going on here?
Old 12-19-2008, 08:30 AM
yeah winter blend sucks. i use to lose about 4 mpgs. its better than your fuel gellin tho.
Old 12-19-2008, 12:08 PM
dmd dmd is offline
Check the real milage, not just per tank.
Cold weather also makes warm up longer to get to a good operating temp. Letting it sit and idle will make this worse. Start it up, let the oil circulate for 10-15 secs, then drive easy until the temp needle starts to move. That will get it warm much faster. Also less energy per/gallon in winter, that will lower milage too.
Old 12-19-2008, 12:10 PM
a truck
Yeah you will lose mileage with the cold weather, that happens to me too, also just to double check, when is the last time the fuel filter was changed?
Old 12-19-2008, 02:03 PM
Powerstroke Junkie
Mine is good for a 2.5 to 3 mopg difference. All depends on where you live and how much the fuel is cut, this will of course depend on temps, so usually the further North you go the worse the mileage. Another cause would be bad injector cups can also drop fuel mileage.
NCH
