Storage while deployed - Ford Powerstroke Diesel Forum
Old 12-18-2008, 11:09 PM
Northwest Stroker
Only leaving for 7mos starting Jan. Read another thread about flushing all fluids half way through, then flush again when I return. Any more comments, or not that necessary to go through all that?
Old 12-19-2008, 07:04 AM
Left mine for almost 7mo in long term on base. Just disconnect the batteries and it will be fine.
Old 12-19-2008, 07:06 AM
Mine was parked for three years while recovering from a BAD accident (explosion), and yes the dually is fine.
Now I had to drop the tank, clean it out replace the fuel sending unit in the tank, change fluids (oil, rad., tranny, and diffs) , oh and two new batteries. Needed the neglected maint.. I also had to replace the cam sensor since it was off line for the recall.
When we did a reading on the computer to find any problems it read (0) issues??? Never seen a clean slate before? But thats what I had to do, and it was 36 months. I should have started it more often?
Anyways thats my .02 worth.
Bill
Old 12-19-2008, 07:46 AM
Northwest Stroker
sounds great thanks for the response
Old 12-19-2008, 02:51 PM
Powerstroke Junkie
Either drain the tank or add some fuel stabilzer to the fuel and run it through the engine,then I would rain the fuel bowl, disconnect the batteries and have a safe trip!!
And Thank You For Your Service!!!
NCH
Old 12-19-2008, 03:05 PM
NCH
and maybe some extra air in the tires, may prevent flat spots and dry cracking.
i'm leaving for some training in Jan and will have to do the same.
Be safe
Hooah
Old 12-19-2008, 03:22 PM
lifetime member
might try nitrogen in the tires
Old 12-20-2008, 09:50 AM
Powerstroke Junkie
I wouldn't worry about the tires for 7 months, if it was longer I would recommend putting the truck on jacks and removing the tires, or at least getting them off the ground.
NCH
Old 12-20-2008, 10:02 AM
Ole White
Have a save trip and THANKS FOR YOUR SERVICE ! !
