snow blade info - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-18-2008, 03:53 PM Thread Starter
Huetty1's Avatar
snow blade info
I have a chance at a snow blade that came off of a 2004 f250 wondering will it fit my 99 f250 with out any complications?
Huetty1 is offline
post #2 of 4 Old 12-18-2008, 03:54 PM
layson's Avatar
Quoted: 82 Post(s)
Everything is pretty much the same on an 04. I would think you would be just fine. 05 is when they changed the front end around a bit.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is online now
post #3 of 4 Old 12-18-2008, 07:03 PM
NYMustang50's Avatar
Different mounts are used I'm sure of it. Find out the part numbers of the plow and mount and everything and I will get you better/more information. Also check out plowsite.com I'm a member there as well.
NYMustang50 is offline
post #4 of 4 Old 12-18-2008, 07:23 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
99-04 the mounts are EXACTLY the same. 05 up is when they changed
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
