ok so i have a 2000 7.3 and it has the elctricshift 4x4 and its not working it seems like it has no power
also when you switch it does the light on the dash go to 4wd? can you hear/feel the motor engage it into 4wd? |
no nothing is working i even took a test light to see if it had power and it dosent the only wier that has power is the switch light
have you checked your fuses? -Raul |
ya i did and non of them where blown
what about checking that the electronic actuator is getting power?
could be a cut wire somewhere.... but if its getting power its a bad actuator |
i checked the wiers that go to the transfercase and they had no power ether
then you got something wrong in the electrical system that your not getting power to the motor.... start tracing the wires... prob cut somewhere
ok thank you i have had the tranny replaced two times so i dont know if mabey they left a groung wier off or something ands where to look for onr
