7.3l Block heater
Does anyone have pictures of where the block heater plug on a 99 7.3 would be at? I killed my batteries trying to crank the truck for my first time in cold weather...so im researching alot trying to avoid this mistake tomorrow.
well i don't have any pictures, but on my early 99 the cord is right under the radiator and comes out bhind my front liscense plate
I just went outside and checked it out..i found it...do you plug it up all night? How would I know if my glow plugs are going out?
I plug mine in all night. But that is because I never know when I may get called into work. But you do need it plugged in for a minimum of 3 hours for it to work.
if i know im not on duty for the local fire dept., i usually use a timer to turn mine on,
I'm on call 24/7 the great life of being on a prison disturbance control team.
do yall know how to tell if my glow plugs are going bad...or are already bad.
bump......
How cold was it?
Your GPR could be going bad. |
