Extend Oil Service Intervals - Ford Powerstroke Diesel Forum
Old 12-13-2008, 06:57 AM
Not to start a war ,but I wanted to get the general thoughts on oil services.
Here are my questions.
1.) Bypass filteration systems? What are the perfermed systems? Have people been happy with them. Any report and tests? Install procedures
2.) Oil. What are the preferred premium oils? Test and data
I have a attached my baseline. This is a 2000 Powerstroke with 63K miles on it. The oil was Rotel T 15W40 with 4 K miles on it. The top end (HPOP reservoir) and bottom end are changed together.
My baseline results were:
Wear Metals (PPM)
Cu 9 Fe 12 Cr 0 Al 1 Pb 2 Sn 0 Si 2 Na 2 K 8 Mo 2 Ni 0 Ca 2172 Mg 77 Zn 1149 P 994
Oil Condition/Particle Count (ct/ml)
ST 0 Oxi 17 Nit 5 SUL 20 W N A N F N V100 13.6
What service intervals are people running? Runing bypass? Oils? Let have data not my friend said.
Thanks
Old 12-13-2008, 12:06 PM
I was thinking of running the amsoil pure synthetic 15-40 and it says it can go up to 15k or a year on severe use on the truck if you use one of there filters as well. Maybe someone will chime in on there product and we can know if it is possible.
Old 12-13-2008, 12:14 PM
I just installed a FS 2500 and amsoil 15w40 about 2 months ago. It has noticeably quieted the engine and I have seen a slight increase in mpg, nothing huge but .5 mpg or so. I havent put enough miles on it yet to see what kind of service interval I will be able to go. Install was quick and easy. Let me know if there is anything I can help with
Old 12-13-2008, 01:09 PM
Is that necessary? I've heard both sides but haven't seen any facts. Just wondering your input.
by-pass filtration does WONDERS and I'm not sure it matters who's "kit" you use, or make your own. It's a "technology" that filtered down from the long-haul industry as is running centrifuges on engines. Now the filter makers are kind of combining two filters into one, a by-pass set-up so to speak.
Old 12-13-2008, 04:00 PM
Powerstroke Junkie
No this isn't necessary. People are watching that idiot on the internet and now this "draining the HPOP" is all over the forums. It is a good way to get air into your HPO system and these things can be a real pain to burp that air out of!!!
Extended Oil runs needs to be done right, and if done right, I don't see a big advantage over reg changes. For a bypass system the single Amsoil is okay but filters are way to expensive, the FS2500 is way over priced, but somebody has to pay for their 6 pages of hype in every diesel mag on the planet, the oilguard single bypass is probably one of the best reasonably priced systems out there. In order to run extended service UOA's are critical, so you know how your oil is doing, the full flow still has to be changed at regular intervals. So buy the time you figure the cost of all this in there really isn't much savings to be had. The dyno oils of today are far supperior to lubricants 20 years ago, and changing the oil and filters at regular intervals is key to prolonging the life of your engine and powertrain. I am going to add a single bypass system to my truck, not for extended service though, I will still continue my 5K intervals, every UOA I have done ( every third oil change) they all tell me to go 7500 on the next sample, but I prefer being safe than sorry. So add up the cost yourself, only you can say if extended oil service is good for you.
NCH
Old 12-13-2008, 04:34 PM
eventually I'll add a by-pass system too, just for complexity's sake Like NC said, lube and filter tech has come a LONG way even in the last 5yrs. of course the demand these engines (mfgrs) place on lubricants is CRAZY (no more using corn oil in a pinch).
