Wheel spacer for a dualley? - Ford Powerstroke Diesel Forum
Old 12-13-2008, 06:46 AM
Does any one make a wheel spacer for a dualley. The tires I want to use are 265/75/16r. I want to get a certain brand/tread and still have my load range E. All the tire places I have talk to have said the back tires will rub. Or has any ever made thier own. Thanks -Trevor
Old 12-13-2008, 06:54 AM
Ole White
Yes they make wheel spacers for dually's check with Raul from Stealth Automotive he's a Supporting Vendor here he should be able to get you some
Old 12-13-2008, 07:03 AM
Thank you sir, I will do that! Thanks -Trevor
Old 12-13-2008, 07:40 AM
i know they make all kinds of spacers but what type of spacers do you all use..the bolt on ones or just the spacer.
Old 12-13-2008, 03:48 PM
Powerstroke Junkie
Trust me you need to be very careful with using spacers. One of our members could have been killed on the way to SSS08 due to bad spacers. I suggest you talk to him, his name is Mudrunninpig "Mike" , heck of a nice guy and he will tell you what you need to know. He finally got some quality units made from a guy in CA and he has been real happy with them.
NCH
Old 12-13-2008, 04:39 PM
265's will not rub in the back, you dont even have to worry about spacers.
Old 12-13-2008, 04:42 PM
I've seen 265s rub while loaded...unloaded no.
Actually saw a set that the sidewalls had exploded....looked cool, but I can't imagine it was any fun.
High quality hub-centric billet steel spacers are the way to go, IMO.
Old 12-13-2008, 08:44 PM
i just put a set of 265's on mine and i wouldn't even put em on without spacers,let alone tow anything. there was only about 1/2 inch at the most between the sidewal and mounting flange on the wheel. i got a set of 1/2 inch spacers,can't tell you they work great cause i just put em on. if you don't pull anything really heavy you might wanna get some a little narrower to have some more room on the machined part of the hub for the wheel to sit on.
Old 12-14-2008, 09:59 PM
285,261,190
Contact Fred Goeske. (818) 992-5700 He makes custom spacers. A great guy and very knowledgeable. He can machine you anything you want. Please if you go spacers make shure they are hubcentric. I speak from experience. Also make shure the studs being installed are factory grade. Cheap spacers can only cause headaches. And or accidents......
Old 12-14-2008, 10:18 PM
Send a message via AIM to harrys91rs
+1 for Fred Goeske. I have his 2" steel spacers on my 00 truck with the 07 20" harley rims, no problems. I think fred uses the oem ford studs with his spacers too.
