On Board Air
So I am almost ready to start my on board air project and i need some advice. Has anyone put a york compressor in the spot for the second alternator could go. And what size compressor are most of you running. I would like to be able to fill a 5 or 7 gallon tank pretty quickly. What CFM should I look for.
I don't have a York.....but my system is better than those 12volt air compressors.
I run a 115volt 2.5hp constuction air compressor,..and it is powered by a 10,000watt inverter...... .....so I can now also run anything that is 115v,..right out of my truck. ![]() ![]()
If you're looking for info on what York to get, check some jeep sites. Different Yorks are rated for different outputs. I don't know which ones to look for, but I know that info is out on various jeep sites. It seems most Jeeper's with Yorks seem to be quite happy with them. Air tools shouldn't be a problem with a York (well maybe sandblasting might be but I never heard of anyone using the air from their jeep to run a sandblaster!). I'm guessing you'll be putting in a tank somewhere as well?
I love the setup TANK but I want somthing a little smaller I am mounting the tank under the truck and it will mainly run Horns but I will plumb a Quick connect at the back near the Tailgate because I would like to be able to run simple air tools (ratchet, impact gun, maybe a cut off wheel but they use a lot of air.) I heard that horns will get about 2-3 blast form 5 gallons. It just needs to refill quickly.
