PLEASE HELP battery problems!!!!! - Ford Powerstroke Diesel Forum
Old 12-10-2008, 11:42 AM
Exclamation PLEASE HELP battery problems!!!!!
Ok I really need some help here. I have posted a few times with electrical problems and really haven’t received much advice but I think I am narrowing down the problem so maybe it can trigger something now.
I have two new batteries and a new alternator in my truck and when out there at lunch today and it was deader than hell. I’m not leaving anything on but here is the tricky part. If I drive to work and park my truck like any normal person it’s fine but if I go back out there to get something out during the day and shut the door and walk off without starting it both batteries will be dead in a couple of hours. I can’t see that anything is staying on like cargo light or anything. This only happens when I open the doors after my truck as been sitting there for a couple of hours. I do not know what all comes on when you open the door like Cargo light and stuff or when I shut the door could it be rattling something to close or open that doesn’t do it right after turning the truck off. What gets me is it has to be a pretty big power source to drain the batteries in a couple of hours.
The only fix I have is I carry an extra fully charged battery in my truck to change out with it happens.
I only have to change one battery and it starts right up. I change the passenger side one if that matters to anyone. Everything I have done to my truck is in my sig.
Old 12-10-2008, 11:50 AM
Well, I don't know why or what is doing that but I can tell you how to figure it out if you want.
All I can think of is something is coming on that is triggered by the door circuit. First things first. In all my years of electrical diagnosis these issues are almost always caused by aftermarket installations. If you have a stereo, amp, or anything like that then you need to unplug that first and see what happens. If you want to know the procedure to find out what is causing it after that I will be more than happy to help but it's a lot to type so I don't want to waste my time if your not going to follow through with it.
Old 12-10-2008, 12:09 PM
PM sent
Sent you a PM with my phone number
Old 12-10-2008, 01:21 PM
I want to start by saying that 99% of the time these issues are aftermarket related. I am not saying you didn't wire your stereo or whatever correctly, it's just a fact. So if you have something that was installed aftermarket then I would start there.
Go to whichever battery is easier to use and loosen the negative cable and get ready to take it off. Put one lead of the meter on the battery post itself and one lead one the battery terminal. Now slowly and carefully take the terminal off the post without losing your connections to the meter. This is easier to do with helping hands or a special tool but you can do it if you take your time. The reason you don't want to lose the connections is that you could "wake something up" and that will give you a false reading. Now your going to need to clamp the meter leads onto the post and terminal somehow if you plan on doing this yourself otherwise you can get your buddy to do the rest. See what your meter reading is and remember that. If it's less than 1 amp you probably have another issue. If it's over 1 amp then you need to start pulling fuses one at a time. Once it drops you need to stop there and mark it and also remember what the drop is (probably best to write all of this down). Continue until you've pulled all of the fuses. If you have more than one which I am sure you will, I would start with the largest amp drop and go from there.
Now that you know what circuit you need to look at you need to know what all is on that circuit. Once you know that, start unplugging things on this circuit and continue until you find the problem.
I hope this helps.
Old 12-10-2008, 01:30 PM
I had the pcm for the lights and other stuff that would WAKE itself up and drain my batts on my other truck,replaced the pcm but that truck had gremlins
Old 12-10-2008, 01:42 PM
getting crazier
Put a new battery in it about 2 hours ago and everything was great let it run for about 15 minutes turned it off and went inside. Just now went back out there and both batteries are completly dead. What in the world is going on and what could drain the batteries that quick
Old 12-10-2008, 02:34 PM
Lifetime Premium Member
It would have to be something that draws alot.Maybe Glowplug relay..sticking
Old 12-10-2008, 03:53 PM
Yeah, its gotta be big time draw. That glow plug relay may be your culprit.
Old 12-11-2008, 04:08 AM
still broken
We'll we worked on trouble shooting it last night and ended up blowing a fuse in the meter but the problem is getting worse so maybe that means easier to find or some good ideas if anyone has any.
Now if I unhook one of my batteries right after I turn my truck off you can watch the light under the hood go dim in about 5 minutes. Whatever is cause this is a BIG drain and I can't think what could be draining it that fast. I drove it to work this morning and got out and unhooked the passenger side battery waited about 10 mintues and the other battery was completely drained
ANY HELP ANYONE?????????:dunno:
Old 12-11-2008, 06:33 AM
I did some research last night and I found a way to measure the current draw without blowing fuses. Only problem is I don't really understand it so I'm going to have to think about it for a while. I'll look at the schematics later. My fuse is 10 amps and you are obviously pulling more than that Glad you made it to work this morning!
