Front axle, leveling kit help!!! - Ford Powerstroke Diesel Forum
Old 12-10-2008, 10:41 AM
so i have my leveling kit in, but now i need to line up the front axle to bolt it back together....and im having trouble...any pointers? maybe to make it easier
Old 12-10-2008, 10:45 AM
Is the track bar on? Did you take it off to install? Was it full replacement springs or add a leafs?
Old 12-10-2008, 10:47 AM
Unapologetically American
Feedback Score: 4 reviews
Aren't there center pins on the bottom of the springs, that line up with holes on the spring perch?
Old 12-10-2008, 10:52 AM
yeah, its a mini pack about 2 3/4 inchest, instructions said to remove the sway bar end links, i loosend them but did not remove, figure i could do it with out removing them. So were im at right now, the leafs are bolted together by the centering pin, the axle is suspended by a floor jack, but i am ahving a hard time manoovering the axle to get the holes to line up with the centering pins. Any tricks will be taken into consideration becuase it is raining out here and ill be finishing it in this weather.
Old 12-10-2008, 10:53 AM
I have an 01 so it is leaf suspension in the front end
Old 12-10-2008, 11:03 AM
Maybe try removing the end links like it says?
Old 12-10-2008, 11:13 AM
yes thats what i figure might make it easier,
Old 12-10-2008, 11:21 AM
Id at least try it. You never know, it may be why it was in the destructions.
Old 12-10-2008, 11:37 AM
Try using a pry bar and get an extra set of hands to maneuver the jack. The person on the jack can move the handle side to side to try to inch it also.
Old 12-10-2008, 03:37 PM
Loosen everything up. Leaf spring bolts, trac bar bolts, axle u-bolts will give you more wiggle room also.
