Ok well I did the water pump on my truck. But today when I popped the hood to check the coolant level. I always do that once everyday for a couple days after draining it all.
I noticed my belt was damaged. At first I thought it was because of me installing it and not getting it right on the pulleys. So I released the tension and checked the idle pulley and tension pulley. Well I noticed my tension pulley has a dent in it from what I don't know. But it also has some play in it. Bearings are probablly bad. I also noticed before removing the belt it walked one groove back on the tension pulley.
Now I can replace the tension pulley cost is 32.00 for just the pulley.
Or I can replace the whole assembly with two new pulleys. The grooved one and the smooth one for 65.00.
So what would you guys do. I also need a new belt too. Which is 41.00.
had the same problem, that darn spring shook like crazy! made all sorts of vibratings, and the 1/2 inch hole busted to boot, cheap crap aluminum! replace it all, make sure you get the belt on right, i know it sounds like your father, but i tore up a new belt when i replaced my spring , you gots to check all pulleys 10 times, cuz i swear i checked mine twice, nope! still was wrong, good luck!
Didn't I tell you to check the tensioner when I gave my recommendations of what to do while you're changing the WP? I usually terll folks to check the tensioner as they go bad often!! I too would replace the entire assembly!! Call Powerstrokeshop.com and see what they can get you the part for.
Did you replace the coolant with ELC?
No I replaced the coolant with the good old greenstuff.
Now I thought the problem was the water pump. The belt that was on the truck was damaged the same way. I thought it was from the water pump pulley walking. As when I checked the tension pulley. It was tight, but it happened with the new belt so I reinspected the tension pulley and that is the only pulley that was off alignment.
Now I have another problem. I need a new block heater cord, mine is damaged and not repairable.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
