My drivers side valve cover says Aug 00' for the build date. I know the transition took place somewhere around that time. Any way to tell without popping the inspection plug out and looking at the rods?
NO You don't need to look at them!! You can tell by the serial number. Maybe the mods ( hint) can make this a sticky!!
Here is the engine serial number break down for the forged and powdered connecting rods. Check you engine serial number on the valve cover build sticker or you need to look at the block where the oil cooler is bolted to it .
Start of production thru 1425746 are Forged Rods
1425747 thru 1440712 are Powdered Rods
1446713 thru 1498318 are Forged Rods
1498319 thru final production run are all powdered
Or you can break them then you know what you have-Ha Ha-Just kidding
The reason for the break in serial numbers is a "test" run to be sure there were not any issues with the powdered rods. Once the process was production tested the powered rod process was used until the end of production.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
