Ebpv????? - Ford Powerstroke Diesel Forum
Old 12-07-2006, 06:25 PM
Ebpv?????
is there any spicific reason to take it of? like hp gains, or do most people do it to make it a exhaust brake????
Old 12-08-2006, 02:43 AM
i hear that it makes your exhaust less restrictive and will give a slight power increase. the reason im doin it is because of the added turbo noise
Old 12-08-2006, 03:09 AM
Moderator
Send a message via Yahoo to 00powerstrokin
i made mine an exhaust brake and love it!
Old 12-08-2006, 05:37 AM
Powerstroke Techie
you should see a decrease in the exhaust temp, and it will be louder. I saw about 50-75 deg reduction in exhaust temp
Old 12-08-2006, 05:39 AM
The Fat Mod
I turned mine into an exhaust brake too, and loved it.
Old 12-08-2006, 12:49 PM
Okay, whats a ebpv and how do I take it off. Does it make any difference removing it? I don't tow any thing that heavy, Maybe I'll make it a brake...is there a page on how to make it a brake? Kelly
Old 12-09-2006, 09:11 AM
I would like to know this also and how to just remove it properly also well removing this cause problems warming up in the winter
Old 12-09-2006, 12:03 PM
Nuckin' Futz
Is there a good way to turn it into a brake...ive tried and i don't think its coming on. I tried another way other than just putting it on 12v switched power and it didn't seem to come on...although there is no reason it shouldn't have. i don't know if it takes a little bit of time to come on or if it just isn't working. i know the valve works cause it came on and it pissed me off so i pulled the truck over and disconnected it on the spot.
Old 12-09-2006, 08:11 PM
Powerstroke Diesel Enthusiast
On standards wire the solenoid to 12v and a toggle switch theirs your exhaust brake, automatics you need a kit because if your towing and you throw the switch on it can destroy your tranny because of the torque converter/lock-up
